Results 1 to 9 of 9
Thread: Couple of Quick Questions
    Jun 2016
    Lakeland, FL
    30
    Question #1: I was testing my TA with my Taylor K-2005 test kit. Added 2 drops of first dropper. Added 5 drops of second. Water turned more Blue than Green on the first try and greenish blue on the second try. Added 3 dropper and water turns light orange instead of red no matter how many drops were added. It's a pretty straight forward test. Any idea as to why this is happening?
    Question #2: I ran an experiment. On 6/14 I got my water tested for the last time seriously at the pool store. Today I tested myself with my kit as well as took a sample in to the store to see what results they would get (I wanted to see how off they were). Below are the results of each as well as the action I took.
    Here's a few questions:
    - If I drained 6 inches of water it makes sense that my CH dropped. Why did my CYA levels go up so drastically (Assuming the initial test was even accurate)?
    - Would adding 6 inches of water make my TA levels spike 40 ppm?
    - During the first test, they recommended phosphate remover. Not knowing better I added it. I've been cleaning the filter every time it gets above the recommended PSI and the cloudiness is improving slowly. When I inquired as to why my FC had jumped so high the Pool service manager said the phosphates were being removed so less chlorine was being used. I questioned this as I didn't believe that my SWG could pump out that much Chlorine and also given the fact that other than adding phosphate remover, nothing much has changed in the past 36 hours. Can phosphate remover really change the FC that much?
    6/14 Store 6/16 Store 6/16 Self
    TC: 0 TC: 5 TC: 2
    FC: 0 FC: 5 FC: 2
    CC: 0 CC: 0 CC: 0
    TA: 90 TA: 130 TA: ??
    CH: 500 CH: 450 CH: 450
    CYA: 60 CYA: 100 CYA: 100
    Salt: 2900 Salt: 3100 Salt: N/A
    Phosphate: 2500 Phosphate: N/A Phosphate: N/A
    Recommended: No Action Rec
    Drain 6in and Refill
    Add Psphte Remover
    Add 45lbs Salt
    Increase SWG to 100
    FL Resident
    IG 18,000 gal plaster
    Hayward Swim Clear Cartridge Filter
    Hayward Swimpure Extreme swcg
    A.O. 1HP motor
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,078
    Re: Couple of Quick Questions
    As long as you are not adding CYA either directly or through pucks or "shock", it won't go up. Chalk it up to bad pool store testing, CYA is the one they are usually worst at.
    TA - Maybe. Test your fill water (tap) Again just ignore the pool store testing.
    Phosphate remover - No clue, sorry
    If your CYA is reading 100, it might be higher. Have you done the dilution test?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    This is the most important page on the forum...http://www.troublefreepool.com/conte...ater-chemistry
    Following up on what Mr. B said regarding testing, delete the first two columns of testing. Stop spending time trying to figure out changes based on those. The test kit you have is missing one test you must have, a FAS/DPD chlorine test kit. Read the first footnote on the following page...http://www.troublefreepool.com/conte...its-comparison It can be purchased from http://tftestkits.net/FAS-DPD-Chlori...-test-p47.html
    Welcome to the forum. The friendliest and most effective group of pool helpers on the net.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2016
    Lakeland, FL
    30
    Thanks for the links. I am getting ready to order the FAS-DPD test. I needed something immediately so I got the 2005 to at least hold me over so I could stop relying on the pool store results. As you and I have both pointed out, they are wildly inaccurate in some regards. I'm sticking with the TFP methods.
    I've read the entire Pool School section and have used the Pool Math link as well today. Added 2 containers of 8.25% Clorox based on my FC test results. I'll have to drain and refill to drop my CYA and CH levels.
    I read that I can lower my TA levels by dropping my PH down to the low 7's. Then when I want to raise the PH back up I can aerate. Is that still correct?
    FL Resident
    A.O. 1HP motor
    38,371
    Before you order the FAS-DPD test ... also get more CYA reagent, maybe some CYA testing standard.
    The SpeedStir is also a great addition.
    And the pressure gauges they sell are very nice too
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Once you confirm what your TA is from your testing, you can then determine if you have other issues (discussed in the following link) that would lead you to need to lower TA. You don't want to lower TA just to chase a "prescribed" number.
    Here is the article on how to properly lower TA...(hint - you had it correct).
    http://www.troublefreepool.com/conte...tal-alkalinity
    Jun 2016
    Lakeland, FL
    30
    I actually read that as you were posting it. I just want to thank you and commend you on such an informative section. Pool School has given me a great insight that I otherwise wouldn't have had. Seems that if my TA test is right, 90 then based on the other levels, my Saturation Index is only .15 which is within acceptable levels (I believe). So maybe I'll redo my calculations on Pool Math to reduce my CH a few more points. I'm at 450 now and I'd feel more comfortable at 400.
    FL Resident
    A.O. 1HP motor
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    You're right on track - good job! If you feel you've received helpful information I'd encourage you to visit our supporter page. TFP is ad-free and a 501(c)(3) charitable organization dedicated to teaching people like us. CLICK HERE to Become a TroubleFreePool.com Supporter!! I've donated several times over the years, giving back really just a portion of the money I've saved by using the methods here.
    Jun 2016
    Lakeland, FL
    30
    Will do! Thanks!
    FL Resident
    A.O. 1HP motor
