Thread: Intex 14x42 round ultra frame above ground pool
    Jun 2016
    Toms River, NJ
    1
    I just purchased this pool. I live on a lagoon so the land naturally is sloped and we have rocks. We rent the house so we can not dispose of the rock. I have set up the pool on plywood to have a flat bottom, leved out the rocks then filled it. Only when it was full did I realize it was way off!!! What is the best way to level it on rocks and is there a way to lift it without emptying the pool all the way. I have already started to empty the pool. It has about 6-8" left to be totally empty. Thanks for the help in advance!!!
    jmcdtucson's Avatar
    Jun 2014
    317
    Re: Intex 14x42 round ultra frame above ground pool
    You will have to drain the pool. I'm sorry
    I'm not sure how you can level on all rocks short of pouring concrete.
    The only other way I can think of is keep pulling out rocks until you have a reasonably level area then backfill with an 1" or two of crusher run (not sand) to cover the rocks still sticking out.
    The pool should be level within 1".
    Pictures would be helpful.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
