Thread: A&A Manufacturing Float Assembly Quik Water Leveler # 529342 vs Korky from Home Depot
    Jul 2013
    Phoenix, AZ
    67
    Hello Team, is there any difference between A&A's part which sells for $30 and the plain old Korky 528 valve at Home Depot for $8.00.
    Thanks!
    10,000 gallon IG pebble pool, 1,200 gallon raised spa, built 2006, Hayward Mega Plus 700 cartridge filter, Hayward Northstar SP4015NS 1.5hp pump, Hayward Super II 2.5hp spa pump w/blower, Jandy AquaLink RS, SpaLink RS controller, A&A Quik Leveler, Quik Clean In-floor cleaning/leaf vac, Laars LX 400 heater, Fiberstars 6004 fiber optic light. Massive delamination of ShastaDeck cool decking.
    Feb 2015
    Chandler AZ
    933
    Re: A&A Manufacturing Float Assembly Quik Water Leveler # 529342 vs Korky from Home D
    My original fill valve failed after about 5 years. I replaced it with a Korky valve, which lasted another 5 or 6 years. The last one I bought was a Fluid master which is going on 6 years.
    The fill valve is just sitting in plan tap water for the most part, just like in your toilet tank - only in a slightly warmer/cooler environment.
    For the price difference I'll use the HD ones.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
