Thread: Pump will not pump water from pool
    Jun 2016
    Villa Park
    1
    I have an above ground pool. The pump is running fine. The chamber fills with water. Once we turn the pump on, the water leaves the chamber but the pump does not suck any water from the pool. When we turn it off, the pump chamber fills up with water again. We just changed the large black ring seal so there is no leak there...
    Above Ground - Sta-rite - 1.5
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pump will not pump water from pool
    Do you have a skimmer on the pool? Is the water level well above the suction line or skimmer mouth opening in the pool?
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    Houston, TX
    1,099
    As Joel said above, make sure your water level is well above the skimmers and the skimmer doors are opening all the way to allow for water flow.
    Next, when was the pump working fine and how long ago was that? Was it working fine before you changed the Blk O-ring? If yes, make sure you did not reverse anything on the pump...
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
