Thread: Hello From MN
    Jun 2016
    Bemidji Minnesota
    1
    Hello From MN
    Hello--
    Hi. Im from a small town in Minnesota. Im new to this. Never had a big pool. just had the little small ones. now I finally got a frame pool for my daughter. its small 12' by 30" above ground frame pool. We have extremely rusty water. filled it up and it looks murky and not good. im new to all of this so im not sure what im suppose to do. Any kind of help would be appreciated!
    Small 12' x 30" pool. Above ground.
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    452
    Re: Hello From MN
    Welcome!!
    Bemidji?!?!? My wife is from Mahnomen. I know they are about an hour apart, but up there, everything is about an hour apart...
    Anyhow, your first step is to get yourself a quality test kit (See link in my signature). For most issues, this is the jumping off point. While you wait for shipment, get a couple handfuls of jugs of either regular concentrated household bleach or Liquid Chlorine. Add about a 1/2 - 1 jug per evening until your kit comes and you can run a panel of tests. Post the results and you'll get good advice from there.
    You may need a metals test kit, given your rusty water, but I would see what your regular panel of test results say first.
    A typical panel of test results consists of
    Free Chlorine
    Combine Chlorimines
    Cyanuric Acid
    pH
    Total Alkalinity
    Calcium Hardness (Not as important for pools with liners).
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    Jun 2014
    15,103
    Re: Hello From MN
    Welcome to TFP!
