Thread: Salt in and above ground spa
    May 2016
    Riverside, CA
    46
    Hi,
    I was talking to my mom about salt pools and mentioned that some people add salt to their pool even without a SWCG, to help with feel and skin. Her question: Could she do that in her above ground spa? Regular, freestanding, self contained fiberglass. Type you buy at the fair.
    Any feedback?
    Appx. 39,000 gal., in-ground plaster. 48 SqFt Pentair DE grid filter, 1 HP Pentair single speed pump, Circupool RJ-60+ SWG (seen here). Currently using Cellulose instead of DE. Hayward XL suction sweep. TF-100.
    JoyfulNoise's Avatar
    May 2015
    13,263
    Re: Salt in and above ground spa
    Not sure what you mean by this...can you post a model name or picture of what you're talking about?
    Matt
    May 2016
    Riverside, CA
    46
    Something like this.
    https://secure.img1.wfrcdn.com/lf/ma...pa-LPI51PE.jpg
    Just not sure if the equipment in these types of spas could handle salt. I'm thinking it would be OK an it's likely all fiberglass and plastic.
    May 2015
    13,263
    The biggest problem would be the heater. If it's an electric stab-in heater (like the ones you find in hot water heaters), then it's not likely designed to work with salt water. It could corrode faster than normal. That would be my biggest concern. If there were an option to upgrade it to something that could handle salt water then you could even use a drape-over style salt-water chlorine generator for sanitation. But the biggest issue would be the heater lifetime.
    Matt
