Thread: Fc/cc test question, new tf100 kit
    newbury2000's Avatar
    Jun 2016
    Phoenix, az
    15
    I'm new to using this test kit, and have a question about the color change on the chlorine test.
    I did the test about 6 times and had investing test results. Fc from 18 to 26. These results seemed to settle out around 22 when i mixed in-between each drop addition. I was adding like 5 to 10 drops at a time to get up to the 40 something drops i had to add.
    Does it matter if i swirl between each drop?
    Second question, for the CC test, when i add the 5 drops of R003, i get a real light pink. Is that an indication or does it need to turn an actual red?
    Thanks for the help.
    38K gallon in ground pool. Painted with an epoxy paint (Pool Guard EHB). Painted over a plaster/fiberglass mix. Triton 2 sand filter with a 1.5 hp motor. suction side cleaner, generic style kreepy crawler style.
    Up to date I have been taken to the cleaners with pool store chemicals. New to this form of pool care. (and excited about it)
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Fc/cc test question, new tf100 kit
    1. Drop, swirl. Drop, swirl. You may like a Speed Stir. If you have very high FC you can use a 5ml pool sample, and each drop is 1.0. You'll fly through reagent doing the 10ml/0.5 method otherwise.
    2. Any pink means CC. If I get a vodka cranberry and one drop makes it go away, I log it as 0.5.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Phoenix, az
    15
    Great thanks! I'll do the 5ml test.
    Jun 2016
    Phoenix, az
    15
    I have another question about the CYA test. I hold the tube down at waist level, look down the tube and add the solution. It is pretty subjective on when you can not see the dot anymore. I find myself guessing a lot when it gets close and I feel like I can see a slight image for a while and i'm not sure if I should continue to add till I can absolutely not see any outline of the dot at all. Or just add till the dot is 95% covered.
    LOL I have been draining and refilling a bunch of water and I find myself trying to add more because I really want the CYA level to be down from where it was.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,460
    Jun 2016
    Phoenix, az
    15
    Thank you,,it did, i did the dilution as it shows,, came out to 60,, did the test straight up and it came in a little over the 100 mark..
    Dang i drained the pool twice down to 1/4 full and refilled trying to dilute the cya.
