Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: First pool test
    Sep 2014
    Phx, AZ
    14
    First pool test
    Initial tests showed:
    FC: 1
    CYA: 0
    TA: 210
    CH: 400
    Ph: 8.2+
    I added cya yesterday, but I've read that it may takes days for it to show up on a test.
    What should I do first?
    Thanks
    IG, 10 yrs old, ~11,000 gallons, plaster, 1hp single speed pump, clean and clear 150 cartridge filter, waterfall, booster pump.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    Re: First pool test
    First off- How are you testing, pool store or a kit of your own? (if kit which one?)
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    Sep 2014
    Phx, AZ
    14
    Re: First pool test
    Tf-100
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    Re: First pool test
    Excellent.
    You need to get the PH down and the Chlorine up.
    Read this to see what to use.
    Read this to see where you should be.
    Use this to calculate how to get there.
    http://www.troublefreepool.com/calc.html
    How much CYA did you add? (Liquid or granular)
    May 2016
    Tulsa, ok
    49
    Re: First pool test
    I'm new to all this but I think you can treat FC and Ph, just wait a good 30 minutes between adding bleach and acid. Don't let the two interact directly, ever. Maybe add bleach, brush the pool, drink a beverage, watch the birds, then add the acid.
    You can also have your CYA in a sock doing its magic all the while.
    You'll have to stay on top of the FC until you get CYA up. You also might have to put quite a lot of acid in to get the Ph down as an 8.2 reading could be in all actuality, higher. If it doesnt initially come down from 8.2, just keep treating it as if it were 8.2 and you'll eventually get where you need to be.
    ~17k gallon, plaster/gunite pool, Pac Fab Challenger Pump 1.65HP, Sand filter. Rheem Heater. Waterfalls with 1 hp pump. Main Drain and 1 Skimmer.
    TF-100XL test kit
    Sep 2014
    Phx, AZ
    14
    Re: First pool test
    Quote Originally Posted by ckk81 View Post
    Excellent.
    4lbs granular yesterday afternoon
    Quote Originally Posted by Cmasty View Post
    Yeah the ph test water was slightly darker than the 8.2 color so I assume it's higher. Thanks for the info!
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    Re: First pool test
    Get yourself some acid and some chlorine and get to work. Follow the instructions listed previously.
    May 2016
    Tulsa, ok
    49
    Re: First pool test
    4# of granular CYA will take you from 0 to 42 CYA -- IF , IF you were at 0. If its still dissolving, I'd consider pulling about a pound out, letting the remainder dissolve and then bumping the CYA again (using poolmath) to the desired CYA number after the initial dose has had 48-72 hours to percolate.
    Don't overshoot your CYA as the only way to reduce CYA is to drain and replace water.
    However - I see that you are in PHX. A high CYA will be good in the desert sun, but I still wouldnt overshoot it.
    TF-100XL test kit
    Sep 2014
    Phx, AZ
    14
    Re: First pool test
    I just tested the cya and it's at 42. It had 0 before I added anything, the mixture going into the tube with the black dot was crystal clear and I emptied the whole sample into the tube and it wasn't remotely cloudy. It's all dissolved now.
    I added 2 qts of muriatic acid this morning before the pump kicked on and let it sit for an hr. After 2 hrs with the pump on (3 hrs total for the acid) the TA is down to 190 and the ph is at 7.2. I'll retest the TA in 4 more hrs like it says to. I just added 64 oz of chlorine and will check that in 30 min.
    Is it safe to swim in today with everything that's been added in the last 18 hrs?
    May 2016
    Tulsa, ok
    49
    Re: First pool test
    What is your CC?
    TF-100XL test kit
    Sep 2014
    Phx, AZ
    14
    Re: First pool test
    The simple test (get pool water and add 5drops) was clear after the drops were added so I didn't test any further and added chlorine. I'll do both tests shortly.
    Sep 2014
    Phx, AZ
    14
    Re: First pool test
    Just tested it.
    FC 5.5
    CC 0
    Ph 7.0
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: First pool test
    Overshot pH a little bit but that's ok. Can you point your returns up to break the surface a little bit?
    What's the water look like?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2016
    Tulsa, ok
    49
    Re: First pool test
    Some of the more seasoned pros should chime in, but I believe you want you want the following in line before you swim. All must be met:
    1. PH between 7.2 and 7.8
    2. FC at or below SLAM level, preferrably in range for your CYA
    3. CC Less than 1.0.
    4. Water should be clear, you can see the bottom in all areas.
    I'm a bit confused on why you added 2Q of MA. Approximately 1Q of normal MA would take you from 8.2 to 7.2, for your pool size. Are you using PoolMath? It's always best to undershoot your numbers and then bump to the desired result. Overshooting creates a yo-yo effect.
    I'll be interested to see where your MA lands after it sets in.
    ^^ What mrBruce said..
    TF-100XL test kit
    Sep 2014
    Phx, AZ
    14
    Re: First pool test
    Quote Originally Posted by Mr Bruce View Post
    They're stuck in place. I can turn on the waterfall though. Water is crystal clear.
    I added 2 qt because that's what the lady at the pool store said to do when I bought the MA. I'll follow the pool math stuff from now on.
    What about the TA?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: First pool test
    Waterfall would be great.
    Yes, please no more pool store advice. Stay away!
    Always tackle pH in 1/2 to 2/3 steps especially at first. Too easy to go too far.
    e: TA is last. How's the water look?
    Sep 2014
    Phx, AZ
    14
    Re: First pool test
    Ok, thanks for the tip and info. How long should I leave the waterfall on? The water is clear.
    What the proper method the move the jets? Mine will not move just using my hand? Is that normal or should they move with little effort?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: First pool test
    Test pH this afternoon, see what you get. Might start to get a baseline for how much that waterfall increases pH.
    If you have eyeball returns, you should be able to move them or rotate them. I don't myself, it's not a big deal if you don't.
    Sep 2014
    Phx, AZ
    14
    Re: First pool test
    Ok, will do. Thanks everyone for the quick help!
  20. Back To Top    #20
    Sep 2014
    Phx, AZ
    14
    Re: First pool test
    Just tested. Chlorine is still 5.5, pH is now 7.2 maybe 7.3, it's a little darker than the 7.2 color but not quite as dark as 7.4. So aerating for 4 hrs brought the pH up ~.3. I'll leave the waterfall on and check it in a couple more hrs.
