Results 1 to 9 of 9
Thread: Cyanuric Acid and Muriatic Acid
    Aug 2015
    Tuttle Ok
    27
    Where is the best place to buy cyanuric acid and muriatic acid? I don't shop at Walmart. Thanks.
    14'X42'' Summer Escapes AGP
    2800 GPH Intex Pump with Hayward S166T Sand FIlter and Krystal Clear SWG
    TF-100 Test Kit w/K-1766 Salt Test and Speedstir
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Cyanuric Acid and Muriatic Acid
    Lowes, Home Depot, lastly the pool store.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Aug 2015
    Tuttle Ok
    27
    Quote Originally Posted by Pool Tool View Post
    Thanks, I will go check out Lowes.
    Pool Tool's Avatar
    May 2014
    757
    MA should be in the Paint dept., look for the 31% strength - not low fumes or anything fancy. My local lowes does not carry pool stuff (no CYA) but most do. Good luck.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    My Lowes (we have many in crowded NJ) does carry pool stuff, but not CYA. I get that on Amazon.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Mar 2014
    south central PA
    112
    Our lowes carries CYA in their (small) pool section. It is chlorox pool brand.
    As Pool Tool mentioned, there are a couple of different strengths of MA. The "green" (low fume) stuff has a lower concentration (at same price). You can use it, but you have to adjust your pool math calculations for the needed amount. The "Jasco" brand carried by our lowes has a regular and "green" version, neither say the actual concentration on the label (I had to look it up online), so just be aware of what concentration you are getting.
    28 ft round ABG with ~6ft deep end, approx. 20,000 gal, 2 spd 2 HP pump, sand filter
    Aug 2015
    Tuttle Ok
    27
    Quote Originally Posted by pigeon View Post
    Ok, will do. Thanks for the info. I will buy some tonight, and make sure I know the strength before using it.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    I see you're in Tuttle. Go to Atwoods in Norman. They usually are a bit cheaper than Lowe's on the muriatic acid and stabilizer. At least the Atwoods here in Shawnee is. Last week I picked up acid for $2.99 a gal there and the stabilizer was right around $20 for 5.5lbs $4-5 cheaper than our Lowe's.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Aug 2015
    Tuttle Ok
    27
    Quote Originally Posted by Jamison04 View Post
    Hi, Yes I am from Tuttle. Neat to hear from a fellow Okie on here. Thanks for the advice, I will have to check it out.
