Thread: Can't find leak
    Jun 2016
    Cinnaminson nj
    1
    Can't find leak
    HELP! I have a 36000 gallon concrete pool. I have been losing water since I opened a week ago. This year we had to drain, replace lost tiles, fix some superficial concrete, and paint the pool. Since we refilled I have been losing water about 2 inches a day. I have shut the pump off for the past 4 days to measure the water loss. Plugged return up still lost water, main drain has been plugged for years, did dye test on skimmer, around light and superficial concrete chips and saw nothing. The water level seems to stop dropping after it hits about 2 to 3 inches below tiles. Pump is still off. Any ideas were to check next? The pool was built in the early 80s. Thank you.
    37 gallon concrete pool. Built in the 80s. One jet,main drain has been plugged for years.
    Nov 2011
    Moberly,MO
    1,010
    Re: Can't find leak
    check the light conduit. Fill pool up and take the light out of niche housing. Dye test conduit
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Re: Can't find leak
    Welcome to TFP!
    This article from Pool School might be helpful, Pool School - Leak Detection
