Thread: New Pool, need HELP with TFPC startup
    We have had a pool for over 30 years and have used the TFPC method for the past 6-7 years with wonderful results. As the liner needed replaced it was obviously time to do a whole new pool. This is the first time we have started from scratch with TFPC method and I am not sure of the order of adding stabilizer, bleach and muratic acid (hard water for much of the fill, so I am sure we will have high TA) with no chemicals in to start with. Need some guidance getting started and then we will be fine. Thanks!
    21 x 41 above ground, vinyl, with deep end; 28,000 gallons; AquaView 24" sand filter, 2 hp pump,
    38,242
    Re: New Pool, need HELP with TFPC startup
    Order matters very little since you can do it all in less than an hour.
    Fill. Circulate. Test. Report.
    You know your CYA and likely also the FC are 0. Add some bleach. Get the CYA dissolving. Adjust the pH. 15 minutes and you may be done initially.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,224
    Hey that's great! Congrats on the upgrade.
    We could use your support to help keep the lights on. It's a modest amount, and it's tax deductible. See the link in my signature "Become a Supporter". There are some perks as well.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
