Results 1 to 7 of 7
Thread: When should I run my pump
    May 2016
    Massachusetts
    14
    My pool is open, running great, and doing all the things it should - thanks !00% to the generosity of this forum.
    Now I am obsessed
    So after running my pump 100% of the time during some SLAMing to elminate Ammonia and then whatever else I am into general maintence mode.
    I am running the pump about 12 hours from 4pm until 4am - but am thinking that might not be necessary or the right time.
    Should I be running this during the day (when the pool gets some occasional light use) or is night the right time?
    Any advice???
    Thanks.
    - 30,000 gallon (16'x40' - 10' at deep end) gunite
    - Sta-Rite DE 60 sq/ft filter
    - AquaCal Heatpump (broken...)
    - new to pools and 110% clueless!
    38,301
    Re: When should I run my pump
    Check out the "determining pump run time" article in Pool School. Likely only need 4 hours of run time.
    May 2016
    Massachusetts
    14
    I did read that, thanks for noting it, but is there a time of day recommended?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    It's mostly preference, enough hours/day for your pool, but the exact time isn't important. I have my timer set for 2-6 so that when I get home from work it's skimmed. Some take advantage of cheap electricity during the night. Some people break it up into different times, a little during the day, a little during the night. Etc.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Mr Bruce has you covered on that. One other point, it can cool the pool a bit if you run at night and warm it a bit if you run during the day.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    All else being equal, I like to run mine during the times I see it most. Reason being that it keeps the surface skimmed, so leaves, flowers petals and pollen are non-existent when I view the pool. They accumulate to some extent while not running and are gone when I look.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    during the swim season mine is usually covered with a bubble cover to retain heat, avoid evaporation & debris getting in. I was running it 3 hours a day
    but recently turned it down to 2 (mark (mas985) had suggested in another post that might be enough, so I'm going
    to try that.
    On saturdays and sundays though I usually run it most of the day (uncovered) for cleaning/skimming/swim times. and heating if it needs it.
    Dolphin E10 Cleaning Robot.
