Thread: Need advice on a pool cover
    Apr 2014
    United States
    21
    I inherited the house with a pool and an old pool safety cover. The pool cover lasted two years and then I moved to a large pool tarp secured by 8 feet water bags and stones. It's a major pain come each opening to remove all the junk from the top of the pool cover. My tarp lasted three seasons and I'm now looking at other alternatives.
    1. Go back to a solid safety cover. I like the safety covers. But some of the screws that go into the concrete are old and rusted. Would I be able to get new hardware and insert them into the same holes or will I have to drill new holes?
    2. Get a mesh safety cover.
    3. Go back to a tarp with a mesh leaf cover. I read the idea here in tfp and sounds intriguing. You can remove the mesh cover in the spring and get all the leaves out.
    Any suggestions on what other people are doing? Also I live in NY, any suggestions on a good place to get a good deal on a pool cover?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: Need advice on a pool cover
    Hi vin, and welcome.
    This is just my .02 so your mileage may vary. I have a solid cover that has a mesh square in the center. I love the combo because you don't have to pump it off but you do not get the mucky water some report with mesh-only cover.
    My concrete anchors are brass...surprised yours rusted.
    Some got stripped from an over-zealous helper last year. In terms of replacement, it was a 50/50 deal...a few we had to re drill...a few others we could just pop the new screw-thingy into.
    I haven't tried the double-cover-leaf-net approach. We just duct-tape an extension pole to a large plastic rake and get anything the blower won't that way. We do that BEFORE the snow hits to avoid a frozen mess come spring
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
