So, our Sharkline Matrix above ground pool (24' x 54") is all up and filled with water. The pool is has all resin parts, but steel walls, so, it looks like it needs to be bonded at four points around the pool. Trouble is... when setting up the pool, there is only ONE spot in the pool to attach bonding equipment (I don't know the technical term, but there you go). The wall was one long piece with no holes for bonding. I was nervous about drilling holes in the walls since I worried this would a) void the warranty on the pool and b) possibly damage the vinyl liner or pool walls over time to have random holes and bolts in them.
If the inspector insists on it, does anyone know a way to get the other three bonding points on the pool? I was looking at the Burndy Waterbug, but that also needs to be screwed through the pool wall, correct? Ideas please...
