Thread: Pinch valve location
    Dec 2015
    Newington, Connecticut
    113
    Received my pinch valve today for use with the liquidator. Does anyone with one know if location makes a difference.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Re: Pinch valve location
    Yes, use it on the input side, after the LQ "ON/OFF" valve.
    Also, if your LQ output valve is above your pool's water level (usually the case with with IG pools, not sure if you have AG), you can eliminate the LQ output check valve, for better flow.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    Dec 2015
    113
    Thanks, Did you eliminate the original flow gauge that came with the liquidator? And just to get it straight input towards the pool equipment. Not input towards the liquidator.
