Thread: Can Wind Increase Acid Demand?
    May 2015
    Moorpark, CA
    171
    Lately I have been going through half a gallon of acid a week, or even more, which is higher than normal. My TA is the same at 60. I have a spa spillway, but only a trickle goes down it. I have noticed it's been windy lately, and there are ripples on the water most of the day. Can wind increase acid demand?
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Feb 2015
    Chandler AZ
    927
    Re: Can Wind Increase Acid Demand?
    Yes - wind can create ripples which in turn aerate the water causing the pH to rise. In addition the spa spillway water flow also aerates the water and the pH will rise.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    May 2015
    Mount Cheaha Alabama
    250
    What's your CH reading?
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
    May 2015
    Moorpark, CA
    171
    Quote Originally Posted by basod View Post
    CH is 400. It's gone up from 350 in the past 9 months, presumably from refill water.
    Michael
