Thread: Hayward TC-15 vs TC-9
    May 2016
    Clearwater Beach, FL
    11
    I have a TC-15 cell that appears to be at the end of its useful life (4 1/2 years of year-round use in Florida). The pool holds 12,000 gallons of water.
    Can I replace the TC-15 with a TC-9 without reprogramimming the AQR? The AQR seems to be working prefectly.
    Is this a wise replacement? Or is the TC-15 better value?
    Thanks
    Rob
    An open (no screen) Pebble Tec 12,000 gallon, below ground saltwater pool on a canal on the Gulf of Mexico. Installed November 2015 with a Hayward Aqua Rite T-Cell 15 chlorine generator, Hayward variable speed pump and 120 sq. ft. cartridge filter. I just found the TRP site and am waiting for my test kit (May 2016).
    Re: Hayward TC-15 vs TC-9
    The T-15 is probably the best choice. Also, note that the software revision has to be at least 1.50 to use anything other than a t-15.
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Quote Originally Posted by JamesW View Post
    And it has to be set for model cell you are using.
    chiefwej
    Aug 2013
    Oklahoma City, OK
    140
    Stick with the T-15 you will get more life out of it since it is designed for a larger pool than you have.
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    May 2016
    11
    It's unanimous! TC 15 it is!
    Thanks to each of you for your responses.
