Thread: How to remove Multiport?
    Jun 2016
    New Haven, CT
    3
    I am trying to replace the filter in my WMC F600 filter and thought I was all ready to go. I have my 300 lbs of sand (the filter holds 260), my multiport is attached with unions so no need to cut anything, and I drained out the water in my filter after turning off the pool circuit breaker. Thing is I can't figure out how to remove the multiport to get at the sand. There is no collar at the top of the filter. Any advice? Please let me know if you need better images or different angles.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: How to remove Multiport?
    I believe this unscrews from the filter body. Take the rest of the pipes off first and try to unscrew it from the filter. If there is a collar bolted onto the bottom of the multiport valve remove it first.
    Love TFP? Become a
    TFP Supporter!
    Jun 2016
    New Haven, CT
    3
    Not sure I am following. Are you suggesting that there might be a collar INSIDE the filter body? The only pipe that was remaining was a short section that is used for backwashing. Any attempts to rotate the multiport have not yielded any results. I haven't tried to force it as I don't want to break anything.
    Jun 2016
    New Haven, CT
    3
    You are correct. What I was able to do was get a long pipe and wrap an end with a washcloth. I then could put it in one of the holes and gently apply pressure to get it to turn.
    Thanks!
