Thread: Where to order TF-100
    Jun 2016
    Edmond, Ok
    3
    From everything I've read, I need to order the TF-100 Test kit. Does anyone have a recommendation on best place to order? The only site I found that clarifies for sure that it's the TF-100 kits that I'm ordering is poolsupplyworld and it says that it ships in 2-3 weeks! What?! I need it now! Amazon was confusing and I found this one (TFTestkits.net) but wasn't sure if it was the correct item?? Also, I hope I'm posting this in the correct place. I'm new here! Thanks in advance for your help!
    15x30; irregular shape; approx 33,000 gal
    In-ground plaster
    Sand filter
    Surrounded by trees and foliage, but receives substantial sun, especially in the deep end.
    38,475
    Re: Where to order TF-100
    Welcome to TFP!!!
    tftestkits.net is the source. They sell on Amazon (with a markup) and sell to PSW to resell on the west coast.
    Sounds like PSW might be out of stock ... order from tftestkits.net
    Jun 2014
    15,221
    Also look for the "Speed Stir" if you can swing it. Mix like a pro. You won't regret it.
    Jun 2016
    Edmond, Ok
    3
    (Nevermind - I figured it out ) Please help! I obviously figured it out once, but now I cannot figure out how to post a new question. Where do I go on the site??
    In-ground plaster
    Sand filter
    38,475
    Browse to the forum you want to post in and push the blue button toward the upper left (like where the "+Reply To Thread" button is located.
