Results 1 to 7 of 7
Thread: No bromine?
    Jun 2016
    Franklin, MA
    9
    Question No bromine?
    Hey y'all,
    We bought a new in-line brominator last year, and it worked just fine. Hooked it up this year, filled it, and pool has been running for about 3 weeks. I haven't been able to get a bromine reading at all, but the pool is clear and smells normal - I mean like chemically normal. I bought a new test kit and still no reading. I emptied & re-filled the brominator and still no reading.
    Why would the pool still smell and look fine if there isn't bromine? I'm really confused by this and I hope someone can offer some insight as well as some suggestions as to what to do next.
    Thank you!
    16x32 In-Ground installed in 1984 / converted to bromine, replaced liner, filter, heater ~ 15 years ago
    Raypak 2100 pool heater
    Aug 2014
    Northern IL
    4,615
    Re: No bromine?
    Try throwing a jug of bleach in there. Chlorine can reactivate your bromine bank.
    Jun 2016
    Franklin, MA
    9
    Re: No bromine?
    Thanks for the quick reply!
    I used some Go-Bro (I think that's what it was called). Nothing happened...maybe I didn't use enough?
    Would one jug of bleach be enough?
    I shock with chlorine-free shock.
    Jun 2016
    Franklin, MA
    9
    Re: No bromine?
    I should also say that pH, Alk, Hardness readings are totally fine. I am at a loss.
    Aug 2014
    Northern IL
    4,615
    Re: No bromine?
    I just tried to google go-bro and that wasn't a good idea....
    I would try one jug and see what happens. When I had a bromine pool, sometimes it took 8-10 gallons to reactivate the bank, sometimes just 1 or 2.
    When I got a new liner, I switched to chlorine. I have never, ever regretted it. Think about it when it comes time to replace your water.
    Jun 2016
    Franklin, MA
    9
    Re: No bromine?
    The pool was chlorine when we first moved in. I am too sensitive to the smell and the chemical itself. Bromine works great for us! I know it can be a pain, but we think it's worth it.
    Aug 2014
    Northern IL
    4,615
    Re: No bromine?
    Ha! So were we... until I learned how to properly balance a chlorine pool. Since then, NO smell, NO irritation, and super-easy maintenance. Much cheaper too! I still have my brominator/chlorinator in-line in case I ever decide to go on vacation. Otherwise, it stays empty.
