Results 1 to 10 of 10
Thread: Hi from Cincinnati, OH
    Jun 2016
    cincinnati/OH
    4
    Hello everyone,
    I found this site after some hunting around and this looks like a good reliable community looking to help rather than to sell me something.
    I've had a pool for quite some time and this is the first year that I have had to really fight a green pool. Cover was damaged during the off season so all the leaves settled to the bottom. Here's what I've done so far:
    - cleaned out as much as I can with a leaf rake - it's not quite as murky
    - balance alkalinity and PH
    - brushed the wall and shocked the pool with calcium hypochlorite (5lbs)
    - added algaecide
    3 weeks in and there hasn't been really much change and I'm now frustrated and at a loss as to what to do and find myself second guessing.
    so here's the current stats:
    FC - 5+
    TC - 5+
    pH - 6.9? 7
    TA - 50
    CH - 110
    CYA - 50
    pool stats:
    IG
    25k
    Sand filter
    vinyl
    Hope you can help! I've currently ordered the TF100 test kit, so hopefully that arrives on Friday so I can get exact numbers on FC/TC/CC
    Thanks in advance!
    Jay
    Sorry about the sideways pics. A few other details:
    - Sand has been replaced
    - 5 lbs of dichlor was added on Monday. That day FC: 4 and TC: 5+ PH: 6.8 TA: 50
    - about an hour before the pictures in OP I add 4 gallons of Liquid shock - 10% concentration
    Now I get the torrential downpour to see how that affects the pool chemistry.
    Thanks in advance for the help!
    Jay
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Hi from Cincinnati, OH
    Welcome to TFP!
    For full disclosure, the guy who pays the bills for the forum does sell the TF-100 test kits. But, with that being said, they are the best value for the reagents you are purchasing.
    With your chlorine at 5+ what have you been using to add chlorine?
    Support the site
    Jun 2016
    cincinnati/OH
    4
    Hi!
    On Monday I added 5lbs of dichlor before I finished reading through here and discovering what it does to CYA. This morning FC was about 4 and TC was 5+
    About an hour before the water test this afternoon I added 4 gallons of liquid shock at a 10% concentration.
    Jun 2016
    cincinnati/OH
    4
    i'm going to repost in the Agae thread
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    124
    Howdy neighbor! Stick around here and these people will help you go from green to clean!
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Green and not very clean
    Nice work so far!
    PH is not valid when FC is above 10. First thing to do with the TF100 is test FC with the FAS/DPD chlorine test. Let FC drop to 9/10, test PH and adjust to 7.2. And then SLAM the pool, SLAM
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    430
    howdy from another neighbor!
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    DFW, TX
    24,483
    Wow, it's an Ohio takeover!
    Welcome to TFP!
    Jun 2016
    cincinnati/OH
    4
    OK, sad day for me. It looks like I didn't make the shipping cutoff on Wednesday evening and even with 2-day my TF100 kit will not arrive till Monday.
    Pool still looks the same, but after letting the filter run 24/7 from the 4 gallons of liquid shock on Wednesday FC is back down to 3-4 and TC is still 5+
    FC - 3
    TC - 5+
    pH - 6.8
    TA - 70
    CH - 110
    CYA - 50
    I'm now stuck in a holding pattern for another 3 days, while waiting on my test kit. Is there anything I can do through the weekend? Can I start the SLAM since I know FC is lower than 5? I just can't measure FC beyond 5.
    I'm currently working on bring the PH up to 7.2.
    25k; IG; Sand Filter; Vinyl Pool
    Aug 2015
    SW Ohio
    124
    Not much you can do without the kit. I'd work on getting the pH to 7.2 like you said and then add 1/2 gallon of your 10% liquid chlorine a day to keep it from getting worse until your kit comes.
