Boring pool water. Time for Borates?
8corneflakes
Platinum Supporter
392
Fort Wayne, IN
Now that I finally understand pool water and never ever have an issue with it, I would like to add borates to my pool. Please let me know if you think now is a good time.
TC always between 3-7
PH always between 7.5-7.8
TA hovering at 100-110
No CC's
Pool clear
A few years ago, we added salt to make the water feel nice and to get rid of some molding cash in our wallet.
If I've never added borates, do I assume that my starting point is 0? If so, Pool calculator say to add 79 pounds granular boric acid.
Is it time? Circle one: YES NO MAYBE
UGH, it has taken FOREVER to get the TA even to 100. After putting in the muriatic acid, it takes a week to get the PH back up again. And this is with all the water features on and 10 kids splashing and using the diving board. I've also turned the return eyeballs 'up'. I've never had to adjust the pH on its own. The pH is ALWAYS within a great range. I only adjust the pH so that the TA will come down. I have battled this the entire time I've had the pool. Every year the TA starts around 125 and I spend the ENTIRE summer slowly adding acid and the aerating over and over again. I have never ever been able to get the TA under 100. Frankly, I don't really care if the TA is high as it doesn't seem to affect how the water looks. I've only tried every year to get it down because I would like to add borates. Usually, it takes so many weeks that I eventually decide there isn't enough summer left to enjoy it anyway. Thoughts?
Mainly because people on here just rave about how great it makes the water feel and how the 'sparkle' is amazing.
I think those descriptions are exaggerations. ;)
Btw, I do use borates, but for different reasons. I didn't notice a difference in appearance or feel when I started using borates years ago.
I'm kinda in the same boat. I did add borax (which currently sits at 30ppm) but TA is back up to 130. Now I want to lower my TA with acid but raise my pH afterwards as well, but with borax you'll raise the TA back again. And like you said, manual aeration takes too long. So quick search for me yield these two potential solutions:
Aeration and PH
My DIY Aerator
I'll be heading to home depot/lowes tomorrow and try to build one myself.
Regarding your "high" TA, again if your pH is stable and you have no other problems then I wouldn't worry about it.
Agreed. If your PH stays 7.5 to 7.8 on its own then no need to lower TA. I like some borates. They don't make it worse and it seems better to me with borates and salt. :)
Interesting thread here. I'm in the process of lowering my TA so that I can keep the pH stable for a couple of weeks and then add borates. My goal is softer water. I already added salt to help reduce the red eyes I was getting, but I want softer water too. I live in a very hard water area, so I could see why if you lived somewhere that already had soft water and you didn't care about keeping algae at bay, you may not need or want to worry about borates.
Adding borates does not soften your water.
I understand that it does not soften the water in the sense that it does not remove the calcium. But the TFP page on adding borates specifically says it makes the water feel silkier, which translates to softer to me. Sure it may be the marketing version of "soft" vs the technical, but I don't think it changes my feeling on adding it.
Well as many people have said ... the change in looks and feel seems to be often overstated. There are chemical reasons for adding it, but only for aesthetics seems like a hassle and waste of money to me, especially where there is a large water replacement in winter ;)
Well as many people have said ... the change is looks and feel seems to be often overstated. There are chemical reasons for adding it, but only for aesthetics seems like a hassle and waste of money to me, especially where there is a large water replacement in winter ;)
I just wonder how many of the folks that added them and didn't notice much change already had silky water in the first place, or at least didn't have water so hard that it bothered them. More than anything, I'm curious. If I notice no difference, I'll let them fade out of my pool. If I do, I'll keep the levels up as best I can. I needed to get my TA down anyway, as my pH was unstable. I'll admit, I'm in less of a hurry to get them in my pool now, but at the same time I am still curious. And even with the added expense, I'm still saving money over using that stupid Pool Frog system the previous owner left me. :)
Realize ... I have a 50 pound box of boric acid in my shed that I have not added yet :mrgreen:
But, I want it for the pH stability due to my SWG raising the pH (my TA is down around 50-60ppm) as well as the inhibiting of scaling in the SWG which I read is a possible side-effect too.
I did not add it last year or this year because I know either this season or next I am going to have to dump my water due to the CH rise and do not want to add it and then dump it.
