Thread: Glass Tile Installation in SC
    Apr 2015
    Florence/SC
    12
    Does anyone know of anyone that does good work? I have a fiberglass pool that i am looking to tile, and i want to use glass 1x1 tiles. TIA
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Glass Tile Installation in SC
    Sorry no one has been able to help, did you find anyone?
    bdrex28's Avatar
    Jun 2016
    Frisco, TX
    247
    have you tried contacting the distributor and asking who they might recommend? I would think they would know who does the installations based on who's buying. If they are a contractor that buys a lot for different jobs you'd think they would do a decent job or else they wouldn't be buying for a longer length of time.
    Brian (Frisco, TX)
    2016 18,250 Gallon IG, Spa, Pentair Intelliflo VS, Pentair Master Temp 400k, , EastyTouch 8/ScreenLogic Surface: Pebblesheen Blue Surf with Abalone, Travertine Coping and Pavers. 3 LED in Pool 1 in Spa. New Frisco, TX Pool Build
    Apr 2015
    Florence/SC
    12
    Guy named Tom Berry is going to do it. He's done about 220 tile installations in the last 3 years, so at least he has a good bit of experience. Hoping for the best! Thanks for the responses.
    Aug 2014
    Houston tx
    2,525
    Please post pics when it's done!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
