Results 1 to 7 of 7
Thread: New pool pump help!!!!
    Jun 2014
    Atlanta, ga
    26
    I just purchased a new Pentair Superflo 1HP Dual Speed pump. Thanks to someone's suggestion in this forum! The good news, I installed the pump and it works great. You can hardly hear it. I'm having trouble with the Dual speed toggle switch. I'm obviously not putting the wires in the right place. I have 3 wires going from the wall to the pump. They are green, white and red. The green one is easy. I put the green one on the green screw. I guess that's the ground. I put the white one on the number 1 top slot. I put the red one on the bottom number 3 slot. Again the motor runs great. What I can't seem to figure out is the toggle switch. There are 3 colors. I put the white one on number 3 and I put the yellow one on number 2. Where does the black one go? I can't figure it out and I don't want to break the darn thing. Any suggestions would be greatly appreciated.
    18K gal, IG Gunite, Sand Filter, TF-100 test kit
    38,272
    Re: New pool pump help!!!!
    Your white supply neutral is correct on terminal 1.
    Your black supply wire should go to the black wire on the center of the switch.
    The white and yellow wires from the switch go to the other terminals (yellow to 2 and white to 3/4)
    There should have been a diagram on the side of the motor.
    Jun 2014
    Atlanta, ga
    26
    It works! Thank you. One more question. The psi on hi is 15. When I click the switch to low it runs at 5 psi. Is that too low?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Nope that's normal. Always use the high setting to determine when to clean the filter.
    Jun 2014
    Atlanta, ga
    26
    Awesome! Ill enjoy the savings!!! Do you run your pump on low 24/7?
    38,272
    Mine reads ~0 on low ... until is gets a little dirty
    No need to run 24 hours. See Determine Pump Run Time
    Jun 2014
    Atlanta, ga
    26
    Thank you sooooooo much! Great information.
