Thread: Help with my numbers
    Jun 2014
    Hulmeville, PA
    42
    Hi everyone,
    I just want to make sure I'm on the right track.
    My water is slightly cloudy and there is a little debris on the bottom. When I scrub it disintegrates so I am thinking it is algae. The powdery stuff.
    I know I need to SLAM. I just got done scrubbing the whole pool.
    Should I bring up my TA first?
    PH: 7.3 or 7.4 (Most likely 7.3)
    FC: 3
    CC: 0
    TA: 50
    CYA: 40
    Not sure why my CC is 0. There is definitely powdery green stuff in the bottom. Not a lot but it is there.
    AG 15x30 wall height 52" - 13,500 gallons install 05/2002
    Astralpool Millennium Series 2000 sand filter 19 1/2 HP
    2.0 HP Pump
    Agua Heat electric heater
    TFT-100 test kit
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    Re: Help with my numbers
    You may not need to bring it up at all. After your SLAM track your pH for a few weeks, if it jumps around, you might need to bump it up.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    38,371
    Algae and CC can be had independently of each other ... there is a reason there are 3 criteria to stop the SLAM process.
    I would leave the TA, lower the pH a bit and SLAM away.
    Jun 2014
    Hulmeville, PA
    42
    Thanks Jblizzle and Mr. Bruce.
    Can I slam without reducing the PH?
    I have bleach but I don't have any muriatic acid on hand.
    I guess, I now understand why the 3 criteria for SLAM. I thought 0 CC meant no algae.
    Thanks for explaining.
    2.0 HP Pump
    TFT-100 test kit
    38,371
    Ideally I would lower the pH a bit more, but it is likely fine to start the SLAM now.
    Jun 2014
    Hulmeville, PA
    42
    Thanks
    2.0 HP Pump
    TFT-100 test kit
