Thread: Loose coping
    Jun 2015
    Ottawa/Ontario
    340
    Loose coping
    One of our coping stones has come loose (ie, i can completely remove it). It appears the glue has come unstuck. Before I head to Home Depot, any tips on best approach to repair? Or is it simply remove, clean area, reapply glue, refill with decking sand?
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Re: Loose coping
    Bump
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Jun 2015
    Ottawa/Ontario
    340
    Re: Loose coping
    Danke! Though i think it is as easy as cleaning the glue and resetting the stone...
