Thread: New member --New Pool Under Construction. Light
    Jun 2016
    Central Valley, CA
    31
    Been lurking on your wonderful site for a few months now, thought it was time to join the community.
    We we are in the processes of building a new IG pool. Nothing fancy; a basic 16x34, ~20k gallon, Gunite/plaster, a bench accross the entire back wall with ~ 1000 sq ft of decking with 5 deck jets.
    Our previous pool pool was much more ornate; free form, grey color plaster, sun shelf, water fall, etc... We loved that pool, but realized we almost never ran the water fall or used the sun shelf. Both were pretty big dirt traps so we omitted them this time. The look of grey plaster, lighter than "Tahoe blue" ,was nice but made our pool very hot in July/Aug...it would exceed 90* from just the sun. We attributed the grey plaster as an attributing factor to holding heat. The deck jets in the pool are almost exclusively to run at night and cool the water a bit if necessary.
    We we are running a 60 sq ft pentair DE filter, Hayward 1.5HP VS pump, and dual low voltage small for factor LEDs.
    Its in in gunite now, was execuvated on 6/1, should be swimming by July 4th.
    triptyx's Avatar
    Apr 2016
    1,438
    Re: New member --New Pool Under Construction. Light
    Fun! If you have pictures, you should open a new thread in the Under Construction forum and share your process, pictures, plans, etc. We love to see new pools going in, and people talking about their construction helps others who are planning to build a new pool as well.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
