Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: My exposed aggregate is too rough. I need to grind it down just a bit.
    Jun 2014
    Roseville, CA
    343
    This is not a new pool.
    We have exposed aggregate that is rough as a cheese grater. I'm thinking of renting a concrete grinder to just knock off the worst of it, certainly not polish it or make it slippery.
    Home Depot rents a concrete grinder that will do jobs like this.
    Does anyone have any experience doing something like this?
    Thanks in advance!
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Apr 2013
    Sacramento, CA
    2,769
    Re: My exposed aggregate is too rough. I need to grind it down just a bit.
    I have my doubts you will like the result. Concrete grinders are not designed for fine work and getting a consistent look over a large area may be difficult.
    If you have a small area that's not noticeable experiment there and see what you get.
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Can you polish instead of grind?
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Jun 2014
    Roseville, CA
    343
    Quote Originally Posted by twinkiesmommy2009 View Post
    Can you give more details when you can?
    My Ideal Specs:
    38,521
    And are you sure you do not just have calcium buildup on the aggregate making it feel rough?
    Jun 2014
    Roseville, CA
    343
    I don't know, actually. I'm thinking of trying an electric palm sander to see what happens.
    What kind of sand paper do I use?
    My Ideal Specs:
    Apr 2013
    Sacramento, CA
    2,769
    Sand paper will last about 5 minutes on concrete if that. You need diamond coated. I don't know if you can buy it for a palm sander.
    Jun 2014
    Roseville, CA
    343
    I'll figure something out. More of a test to see if the roughness is caused by deposits, or native roughness.
    My Ideal Specs:
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    I suggest talking to a local pool plaster company if they have any ideas. Chances are they have tried many things or have fixed jobs where a customer has unsuccessfully tried to remedy a plaster issue.
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
    Jun 2014
    Roseville, CA
    343
    It's not the plaster, it's the exposed aggregate walking surface surrounding the pool.
    My Ideal Specs:
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    It must be the SWG making the rocks harder!! Just kidding, how large of an area are you talking about? You could polish it "a little" and it if gets too smooth you could re-etch the concrete with MA to prevent it from being to slippery.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jun 2014
    Roseville, CA
    343
    It's only about 400 SF. I'm going to try a palm sander on one section where it's fairly hidden.
    I'll do a patch today or tomorrownand see what happens.
    My Ideal Specs:
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Oh my goodness, I've been reading this thread thinking you meant the pebble plaster! I couldn't imagine draining the pool, etc. I wonder if there is a thick sealer that would help smooth out the feel? But that would probably make more of a mess with pealing over time. I'm curious to see what you come up with. Good luck!
    Quote Originally Posted by Chuckiechan View Post
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I wonder about the sealer as well.
    I too had a rough deck (old concrete) and was leaning toward a thick epoxy paint or possible re-coat of a thin
    layer of concrete to deal with it, but probably not what the poster would want to do.
    Dolphin E10 Cleaning Robot.
    Jun 2014
    Roseville, CA
    343
    I got down and looked at it with my 10 power jewelers loupe:
    The large pebbles that are obvious, are mostly smooth. But the cement that bonds, is a mixture of cement and crushed gravel. Tiny, but rough as a cob.
    Attached is a close up. Note the parallelogram shaped stone is ~ 1/2" across. Closeup 2.jpg
    My Ideal Specs:
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    Got it. I recall seeing ads in Houston claiming to "fix" pea gravel concrete. Not sure what exactly they do. Probably put an overlay and stamp it.
    Jun 2014
    Roseville, CA
    343
    I think I'm going to have to live with it.
    My Ideal Specs:
    Quote Originally Posted by philboyj View Post
    That would make the most sense.Grinding down exposed aggregate just seems like opening a can of worms. Grind too little and you now expose more sharp edges, grind too much and you have a slick surface (much like poured concrete flooring) that is a huge headache in wet areas. You can provide flipflops for every visitor for the next decade or so at a lot less cost and headache.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    It wouldn't help for any rough stones, but for the rough mortar areas, an elbow-grease solution maybe to use full strength MA and some kind of a walk behind power tool with a spinning rotary brush (don't know if that exists). The MA would "soften" up the mortar and the metal (probably have to be stainless) rotating brush might take the roughness off of it. I have no idea really but who knows. As a test a drill with wire brush and MA (along with goggles, mask, gloves, long sleeves and long pants) could be used on a test area.
    What I did do once is the following which is what gave me the idea. I had laid a brick patio in plastic trays on a sand base. I then brushed mortar mix over the bricks and watered it down to create a mortared in place brick patio. Problem was that the brick was a slight bit damp (not obviously damp) but it caused a skim of mortar to form on all of the bricks. It looked gray overall. So I used a drill with a wire brush and full strength MA and worked brick by brick. When finished, it was great and "antiqued" to boot. But a major PITA and time sink. That patio was probably 12 x 12.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
  20. Back To Top    #20
    Jun 2014
    Roseville, CA
    343
    I'm guessing I have ~ 400sf.
    My Ideal Specs:
