Thread: TA at 40 but PH holding steady at 7.5 for over a month
    Mar 2015
    Liberty/Tx
    48
    I have a few questions for the expert folks here:
    I have been consistently getting 7.5ph for months now but my TA has been low at 40. (Im using a brand new TFT-100 kit). Should I worry so much about my low TA if I'm getting great ph readings? Last year I had to dump tons of acid into the pool every two weeks to keep my ph levels down. Now it just sits there perfect.
    Do I need to raise my TA to 80 even when I'm not having ph issues?
    If so, can I add baking soda while my children swim?
    Thanks in advance!
    Saltwater 8000 30ft round AGP / 22,000 gal / 1Hp Hayward variable speed super pump / Hayward 150sqft cartridge filter / Hayward Aquarite 25k gal salt system / katchakid
    JoyfulNoise's Avatar
    May 2015
    13,201
    Re: TA at 40 but PH holding steady at 7.5 for over a month
    Your TA is lower than I'd be comfortable with especially if you don't have borates in your water. Since your pH is stable, it's ok but you should keep an eye on both as you don't want either of them to start drifting lower. You could adjust your TA up in 10ppm increments and see what effect that has on pH because at some point increasing your TA will cause your pH to start to creep up.
    Your pool is not in any danger as long as you keep tabs on your pH and TA. They seem to have found a decent equilibrium.
    Matt
    Mar 2015
    Liberty/Tx
    48
    Thanks for the clarification
    30,419
    Stability is the goal. That certainly is low, but if your pool is stable, I would run with it. Check pH often through the summer and pat yourself on the back!
