Thread: Liquid Chlorine Effect on Free Chlorine
    Hi all, I made a quick Google spreadsheet that will give you a quick reference to print and put in your test kit to show the effect on adding X oz / cups of liquid chlorine to your size pool.
    Adjust the gallon number at the top and it will show you how much FC you'll be adding at different amounts of bleach concentration.
    https://docs.google.com/spreadsheets...it?usp=sharing
    Hopefully it is useful to others as they get to know their pools as I am.
    Tom
    Under Construction - Coleman 18' x 48" Above Ground Pool (6200 gal)
    Intex Krystal Clear Sand Filter Pump, 14", 2800 GPH
    Sioux City, IA
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Liquid Chlorine Effect on Free Chlorine
    Nice add Tom, thanks
    Feb 2015
    Chandler AZ
    926
    Nicely done! Thanks Tom.
    Auto-calculates when you change the Pool Size (Gal).
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    Edited for pool size, printed out and will tape to the inside of my TFT-100. Awesome. Now I don't have to go back inside if I forget my phone for PoolMath.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Quote Originally Posted by JoeSelf View Post
    Exactly what I did. Also I verified that all of these match Pool Math. A couple were off by .1 FC but didn't figure that was enough to dig into the discrepancy.
    Sioux City, IA
