Thread: Savi Melody Light Issue
    Jun 2016
    Sunrise Beach, Missouri
    1
    Good morning to all,
    I have one of my two lights, after about 15-20 minutes of turning on, will start to blink, the other is fine. The blinking continues to get worse, and then they are both out of sync. From your experience, what might the issue be. I find it hard to believe that it's a wiring issue, because they are two years old, worked fine from the beginning, and work fine for a short time of being turned on each time. So to me that leaves one obvious problem, the cartridge.
    Your thoughts please.
    22,600 Gallon IG Vinyl Salt Pool
    Savi Melody LED Lights, Jandy Deck Jets
    Hayward: 400,000 btu Heater, Sand Filter, Super Pump, T-15 T-Cell w/ Electronic Chlorine Generator, Aqua-Vac 500 Robotic Cleaner
    Lake of the Ozarks, Missouri
    Jul 2015
    Central Valley CA
    1,109
    Re: Savi Melody Light Issue
    Welcome to the forum!
    You are likely correct. LED's by themselves will last for thousands of hours that is not always true of the drivers, what Savi aka Zodiac calls a cartridge. Do you know if your lights are powered from a single transformer at your equipment pad or do they each have one? If you have 2 transformers I would switch them and see if the problem stays with the one light or moves, that will rule out the transformer as a cause. Even if you have a single transformer it would be worth checking the connections all thought that is not likely the cause. The lights have a 2 year warrantee if you are not much past that I would call the manufacture sometimes they will cover them any way just to keep a good reputation.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
