Thread: Exposed Pipe & Flooring Questions
    joyrox's Avatar
    Mar 2016
    Nashville/TN
    9
    I just bought a 1958 ranch style home in nashville TN that came with a 20 x 40 8ft deep pool thats 35 years old. I had a pool guy come out to inspect my pool and he quoted me around $5k for the liner and the install. But, after he pulled up the old liner he noticed that huge portions of the sand had washed away and so he is recommending that he patch it with Vermiculite and it will cost an additional $1,200. Another concern is that the pool main drain pipe is exposed and he's wanting to just cover it with vermiculite as well and I'll just have small hump on the bottom of the pool? Does this sound normal to you guys? Any suggestions would be helpful, I have no idea what the standard cost is for this kinda stuff or if it's smart to just cover a pvc pipe at the bottom of the pool with vermiculite and the liner. I have pictures but I don't know how to post them to this thread. Thanks!
    IG - Vinyl - 20x40/8ft - 35,000 Gallon - Sand Floor,
    Sand Filter, Installed 1987, Hayward AQR15 Salt System
    2 Skimmers, 1 Main Drain - 2 Speed Pump 1.5 HP-230V
    GLI "Durago" Liner - Taylor K-2005 - Nashville, TN
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Exposed Pipe & Flooring Questions
    Welcome to TFP
    Could you get 1 or 2 more quotes, that will give you a good idea of the cost and most main drains are being plugged or discarded now days, most fail and get covered up
    30,431
    There really is no standard pricing so you'll have to do some home work.
    More and more main drains are being covered up but I would ask him if there was a way he could cut it off and cap it below the pool sureface. I see no reason to have the hump.
