Thread: Wrinkles in pool
    Jun 2016
    Israel
    23
    Wrinkles in pool
    Hi
    I am back.
    The round pool 12 feet. It is verywrinkles.creased, with the bottom at times forming into small "mountins" how and when do i get rid of these wrinkles.
    Jun 2016
    Israel
    23
    jasnovanorder's Avatar
    Jul 2015
    Hamilton Michigan
    201
    Re: Wrinkles in pool
    Just as you start filling work from the center out and smooth out and wrinkles you can. Sometimes it helps to pull the bottom from the outside at first and then work from the center out. Do this with at most 1 inch of water or less. Just enough to hold the liner in place. Any more water than that and you wont be able to move the liner from all the water weight
    Intex AG metal frame vinyl sides 10,400 gal. 3000 gph intex pump with 16" sand filter
    My Slam
