Thread: Intermatic GE pool pump timer making clicking sound, flashing green light, and more
    Jun 2016
    Wichita, KS
    2
    My intermatic timer for my pool filter/pump is making a clicking sound and the light blinks green ONLY when trying to turn on the pump, the Polaris works fine. Electrician charged me to tell me that the switch for my timer was outdated, I don't use the Polaris much so I switched them, guess what, my Polaris works but not my pump. I have checked and checked wiring.
    I just moved into the house and I am not entirely sure of how old the pump or the on/off timer unit is. But I have looked it up online, appears it might be the GE 15132. Any direction would be helpful. Thanks so much.
    BTW, I am currently at work, and I can try to answer questions but may not be able to provide you with the information you are looking for at this time, if you need further information please let me know what you think and if further details could be helpful in determining my problem.
    EDIT
    After doing some research and then more research, I still have not found an answer to my specific issue. The fact that I switched the timers on the Pump and Polaris, and the Polaris continued to work, but the pump still does not turn on, tells me that it has to be due to the electrical hook up to the pump or the connect between the timer and the pump. Thought this was worth reiterating.
    20,000 gallons, IG vinyl, Not sure what kind of filter, not a sand filter though, Not sure of pump brand, Not sure of kind of test kit, I have a GE Intermatic Timer, Do not use well water, no restrictions
    Jun 2012
    western NY
    1,561
    Re: Intermatic GE pool pump timer making clicking sound, flashing green light, and mo
    Having a bit of trouble following this. Is the Polaris a pump, in pool cleaner, or both?
    When you said this... I don't use the Polaris much so I switched them... what did you switch? If you do have a polaris pump in addition to another pump, are both of them on the timer or is one on a separate switch?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2016
    Wichita, KS
    2
    They are on separate switches and I exchanged the the Polaris switch for the switch to the pump.
    Jun 2012
    western NY
    1,561
    When you checked the wiring, what kind of voltage readings were you getting at different connection points. Timer, switch, Breaker, pump, etc
