Results 1 to 10 of 10
Thread: questions about fixing underground pipe
    Jul 2013
    Cedar Rapids, IA
    82
    Hello!
    I'm getting my pool started way late this year due to getting a fence destroyed by a storm fixed before opening. It's incredibly, incredibly green.
    When I fired up the pump, water started flooding up from underground around where the return lines go into the ground. Questions:
    1. Is it a safe assumption that the break is right where the water is coming up?
    2. Do I need to blow the lines out before cutting out the broken piece?
    3. Do I need to drain the pool below the returns or plug the lines before I start working?
    Any advice is welcome. Thank you!
    24,300 gallons, IG vinyl, Hayward Pro Series S244T sand filter, 3ft to 9ft deep
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: questions about fixing underground pipe
    Before plugging or draining, I'd suggest start digging following the pipes to the pool. The break may not be close to the pad.
    The reason I suggest not closing off the returns is it would then be very obvious when you get close to the leak. Hopefully it isn't under concrete!
    Jul 2013
    Cedar Rapids, IA
    82
    Quote Originally Posted by Charlie_R View Post
    Ah, so my assumption in #1 is not all that safe. I REALLY hope it's not under concrete as well.
    If I can find the break though, I take it I do need to plug the returns?
    Thanks for the response!
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    suggestions in bold Blue
    Quote Originally Posted by ChewBiscuit View Post
      Yes - Water may travel a bit underground and come up elsewhere. But that's a good place to start digging and scope around.
      I don't see why as long as you have a valve or a check valve where the equipment is. Do you have a "flooded" system? i.e. Is the equipment below the water line of the pool? That will affect question # 3...
      See question above. If a flooded system, then, yes, use a winter plug while you fix broken PVC
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jul 2013
    Cedar Rapids, IA
    82
    Thanks mikemass. The equipment/pump/filter is all above the water line. If the break is at the first underground elbow like I thought, that would be below the water line.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    perfect. Like Charlie_R said then, dig without a plug in the pool. When you get close to the break you will see the water rushing out. At that point plug the return (using a winter plug) so you aren't digging out a muddy mess. Finishing digging out the area all around the break. Get the PVC good and clean and repair. Are you familiar with using PVC primer and cement? All good once you get to that point?
    Jul 2013
    Cedar Rapids, IA
    82
    Quote Originally Posted by mikemass View Post
    That makes sense. And yep, I'm golden once I get the break exposed.
    Cool, thanks again for the advice!!
    Jul 2013
    Cedar Rapids, IA
    82
    I found the break. I have 2 lines going into the ground that feed 4 returns. One of those 2 is cracked. Can I just shut off that cracked line, and run the pump using only the other line feeding 2 returns? Or will bad things happen?
    May 2013
    Massachusetts
    148
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    If the line you are repairing is isolated at either end (valve off near equip and plugs in the returns) then nothing too bad can happen. Really just a valve or plug leaking.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
