Results 1 to 9 of 9
Thread: Screwed up the pool before we even used it
    Jul 2011
    Galloway, NJ
    23
    I had a popup pool a few years ago and never really got the hang of the chemicals. I really thought that this time would be different, but it's not. I have a 18X48 that we just finished filling yesterday. I do have well water. (That's why it took so long to fill. I didn't want to run the well pump continuously.)
    I only have a cheapo 3 way testing kit until my full kit comes in. I added HTH shock last night. Woke up this morning to a greenish-yellow pool. Chlorine tests at 5 and pH is at 7.2. I'm so lost and I don't even know what I'm looking at in the PoolMath section, because there are so many sections that I don't even have answers for.
    What do I do to fix this? Can we swim in it now?
    18'X48" Summer Waves 7600 gallons
    1 HP Hayward sand filter/pump combo
    TF100 test kit
    Still have so much learning to do
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Screwed up the pool before we even used it
    I'd guess you have iron. As you're a seasonal pool I'd go with a sequestrant. You can see if a local pool store will test your iron content, BUT be prepared to run run RUN from the chemical sales pitch. Pretend it's a cult or timeshare presentation.
    Pool School - Metals in the Water and Metal Stains
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    Jul 2011
    Galloway, NJ
    23
    Thank you. So I just buy the sequestrant and add it? Are the other numbers (chlorine 5 and pH 7.2) ok to swim in? And how fast does the sequestrant work?
    Sorry, I'm just dealing with disappointed kids this morning. And frankly, I'm mad at myself.
    TF100 test kit
    30,432
    Yeah, I agree with ckk81. It sure sounds like iron in your water. Could you post a picture? That would be very helpful.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Jul 2011
    Galloway, NJ
    23
    Here's a picture
    TF100 test kit
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    If it took a long time to fill the green can be due to lack of circulation too. Don't just simply add the agent recommended by ckk81, have the water tested (as he said) to be sure that's part of the issue. Tell the pool store you have all the other chemicals you need at home if they say you need anything else. Make sure you run the pump 24 hrs a day until it clears. Once the chlorine kills, that debris needs to be filtered out of the pool. Also you will likely need to clean the filter more than once per day.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Jul 2011
    Galloway, NJ
    23
    You guys are awesome. I had the water tested, added the sequestrant, and it was clear in just a few hours. Thank you!!!!
    TF100 test kit
    30,432
    Hooray! I am glad that worked.
    Just a sobering reminder....the iron is still there and it will turn your pool again as the sequestrant "wears out". You'll need to replenish the sequestrant when that happens.
