Thread: unlevel
    May 2016
    Missouri
    13
    unlevel
    So we put liner in and started putting water in when we noticed one of the side support rails in the middle is higher than the others how do we fix this with out starting over
    Kc mo, mom of 3 and a farmers wife
    Looking at a 18x40x52 Above ground pool
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: unlevel
    Is this an Intex style pool? How much water is in it now, and how much higher is the support rail?
    Love TFP? Become a
    TFP Supporter!
    May 2016
    Missouri
    13
    Re: unlevel
    This is a above ground 2 inches of water. And the side rail is about 1/2 inch lower than wall 18x40x52
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: unlevel
    Two years ago the liner shifted when we started filling our Intex. One leg was leaning badly, so we looped a tow strap around the tee and used an engine hoist to lift the post so we could reposition it.
    Maybe if you could lift this post you could insert a paver underneath it to make things level.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Casey's Avatar
    SW PA
    10,444
    Re: unlevel
    That post definitely needs a paver or 2 under it. I'd say drain some water, pull the liner back and remove the cove and slide a couple pieces of wood in to hold the load (pool wall) and lift it enough so you can slide the pavers in under the post. These pools are heavy though. You will need some strong men to do this.
    Apr 2015
    Topeka, KS
    13
    Re: unlevel
    I wonder if you could use a jack and a length of 2x4 or landscaping timber to lift it. You'd have to make a decent base to keep the jack from getting buried.
    8,400 gal above ground (Intex type) with Intex SWG and sand filter
