Thread: SWG not keeping up
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    SWG not keeping up
    I am just like everyone else and it just dawned on me this morning answering another post...
    Symptoms: Curcupool SJ45 not creating enough chlorine to stay at 6 FC, last year worked just fine at 50% and July/Aug at 75%... this year at 100% and 12 hours a day not keeping up,
    FC 6 (adding bleach as needed to keep up)
    CC 0.0/0.5 depending on cover on or off
    CH 130
    TA 50
    PH 7.4
    CYA 80
    ***** salt**** it was 3500 at start of season and I have not checked again till today
    Emptied between 5000 and 6000 gallons due to rain over the past 2 months
    checked salt level today and I am at 1500 PPM
    Now I really love the curcupool, it should not even be close to keeping it at 6FC but it has been really close and still creating chlorine
    time to grab 300 pounds of salt
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Re: SWG not keeping up
    1500 PPM is way too low! Salt it!
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    You guys, I mean ya'll not you guys, must have been getting some of that rain up there like we are down here! Nice post!
    Jul 2013
    Fletcher, OK
    3,353
    all of us "in the middle" have been getting pounded with rain... almost 8 inches in under 48 hours...
    The lakes are full now
