Thread: Increasing ph
    Jun 2016
    Nj
    1
    Increasing ph
    how do I increase PH without alkalinity? Is my calcium hardness ok?
    Taylor 2006kit #
    FC 6
    CC.25
    Ph 7.0
    Alk 150
    CH 210
    Cya40
    When I did my base deman test it took 4 drops and Taylor kit says add soda ash 3.lb for 20thousand gallon ..
    I have 35g vinyl ingrown pool with sand filter..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Increasing ph
    Welcome to TFP!
    Here is everything you ever wanted to know about chemicals and how to add them to your pool all on one page, Pool School - Recommended Pool Chemicals
    I would either aerate a bit to raise PH or just wait a few days to see if it rises on its own from the high TA.
    Yes, your CH is fine for a vinyl pool.
    Here is some info on how to put your pool info into your signature so you can stop typing it, Pool School - Read This Before You Post
    30,401
    Re: Increasing ph
    If you want to raise it right now you could use 20 mule team borax and it will have a very minor affect on your TA.
    If it was my pool, I would take pooldv's advice and leave it alone. You can also aerate and your pH will come up and TA will go down.
