Thread: Need advice on chemical balance
    Nov 2015
    Hicksville/New York
    19
    Just got my 100 test kit and started adjusting chemical based on Pool School - Recommended Levels accordingly. I just did another testing and here are the results:
    FC 5.5
    CC 0
    TC 5.5
    PH 7.3
    TA 90
    CYA 46
    These seem like good number to me. (first summer owning the pool) Anything I should adjust? Once the balance is good, what are the next steps? testing PH/FC daily and test everything else weekly? I run the pump 3-6 hours a day and clear debris every morning.
    Thanks in advance!
    L-shape 35" x (18" vertical width, 25 horizontal width) - 26,000 gallons
    D.E Filter
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Need advice on chemical balance
    Those are some sweet looking numbers, great job
    CYA, just use 50 and target your FC at 6, thats is the only thing that I see
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,497
    You got it! Here is a link for you:
    How does the pool look?
    Kim
    Nov 2015
    Hicksville/New York
    19
    The water look clear. There are some dust at the bottom of the pool and I am waiting for a new skinner adapter from Amazon to clean that up. Thanks all
    D.E Filter
    Jul 2012
    Tallahassee, FL
    30,497
    You are good then! Nice job!
    Kim
