Results 1 to 8 of 8
Thread: CYA test
    Jun 2015
    Grapevine, TX
    12
    CYA test
    My CYA test never gets to the point that I can not see the black dot. It (the test kit) is only a year old and I was successful in testing it last year. What gives?
    I assumed the CYA was too high so I drained and filled. No change. Tested my tap water. Black dot all day long.
    15,000 gal, in-ground, plaster (new 2 yrs ago), attached spa, DE filter, AO Smith pump motor/2.20 THP
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CYA test
    If you can see the black dot with the tube full, you have less than 20ppm CYA.
    Jun 2015
    Grapevine, TX
    12
    Re: CYA test
    How do I raise it? That will make balancing my FC levels difficult, right?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: CYA test
    Go to Walmart and buy a 4 lb. jug of it, it is granular. Think it switched to a pink top this year. Also called conditioner. Use PoolMath to try and take it to 30 to start.
    30,432
    Re: CYA test
    Adding CYA to your pool has absolutely no affect on FC levels. Calculate your dosage and test in 24 hours but you can assume it's in there from the minute you apply the dose.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: CYA test
    More here on how to add CYA to your pool, Pool School - Recommended Pool Chemicals
    CYA protects your FC from quickly breaking down in the sun. And it also buffers the harshness of the FC.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: CYA test
    Is it ok to add the stabilizer with the sock method in the skimmer, and turn filter to re-circulate so it doesn't go in the filter?
    Sorry, I wasn't trying to hijack this post, and I was getting ready to ask anyway.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    RNDEBBIEROSE's Avatar
    Jun 2013
    Hornell, New York
    39
    Re: CYA test
    I usually hang my over a return, and give it a squeeze every once in awhile to help disburse it. Works well for me.
    18 foot round AG vinyl 9,000 gallon pool, Hayward Perflex 1 hp pump, DE filter. Taylor K-2006 Test Kit. Pool new July, 2014.
