Thread: pump not starting
    Jun 2016
    Robinson, IL
    1
    pump not starting
    When I arrived home from work tonight I discovered that my pool pump had quit running. When I turn it off and switch it back on, it is humming but will not start pumping. Eventually the humming stops. Therefore I know it is getting power, but I don't believe the motor is starting the pump. I believe it is kicking off when the motor on the back of the pump is getting to hot. I am not able to run it in regular mode or to backwash. I was out of town for the last two weeks and while I was of town had some family check the pool. They noticed that the jets were not really pumping. They opened the pump to see if the basket was full and realized that the water was extremely hot. They turned off the pump and I had a local pool store swing by to look at it. They said that the pump had lost it's prime and they had it back up and running. I checked it last night after returning home and it was running fine. Today after I returned home from work it is doing what I have described above. Any recommendations? Thanks.
    Ryan
    Apr 2013
    Cazenovia, NY
    8
    Re: pump not starting
    Mine is doing the same thing. I've found that if I turn try turning it on multiple times (sometimes 8-10), it will eventually turn on. This has just started happening this season. I'm thinking the pump needs to be replaced, but would be curious to see if anyone offers any suggestions. I have a Hayward 1hp self-priming Superpump.
    Cazenovia, NY (Near Syracuse)
    circa 1968 Gunite 35k gallon inground pool
    Hayward Superpump 1HP
    Hayward Sand Filter
    TF-100
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Quote Originally Posted by ryancorn View Post
    Ryan
    What brand and horse power is your pump?
    Love TFP? Become a
    TFP Supporter!
