Thread: First time owning a pool..Are we on the right track?
    Jun 2016
    Jeffersonville, IN
    2
    Hello TFP crew! My boyfriend and I acquired our pool last fall when we bought our first home, so this is our first season as pool owners. I think Iíve done a fairly ok job of teaching myself how to care for the pool, all thanks to this website. Iíll include some background information in case itís relevant, but if itís not, feel free to skip to the bottom of my post for my water levels and questions.
    When we bought the house, the pool was stated to be in Ďworking conditioní. But it was also left closed all season long last year, since the house was for sale during that time. After pulling the cover off and getting the pump and filter hooked up, we discovered the pump was no longer working. This was unexpected, and we had to wait for payday to purchase a new pump, so about a week went by with the pool just sitting there, not circulating with full exposure to the sun. During that time, the water went from slightly cloudy to completely dark green and full of algae.
    We bought a brand new pump, and also a new cartridge filter, and got everything hooked up and working. Using the awesome instructions from this site, we SLAMed the pool. Over the course of about 4-5 days, the pool went from sickly green to crystal clear. It was like magic, and we never could have done it without TFPís easy to follow directions. I have really good before and after pictures if I can figure out how to post them here.
    So after lots of hard work SLAMing, the pool is looking great, and weíve even swam in it a couple times. I couldnít get the Taylor test kit ordered in time for us to start the SLAM, so we bought a cheap reagent test kit at Meijer to give us an idea of where to start with chlorine amounts. Thatís where I think I messed up. After the pool was cleared of the green, I used the cheap test kit to test the CYA level, and it read zero. I was worried the sun would break down the chlorine faster than it could keep the algae away, so I added the right amount of stabilizer, using poolmath.com, in a sock in the skimmer.
    About a week later, yesterday, the Taylor test kit was delivered and I was finally able to do a thorough, accurate test of the pool water. The results were:
    CYA 65 ppm
    FC 0
    CC 0
    TA 0
    pH <7.0
    Calcium Hardness 80 ppm
    So basically the water has nothing in it except high CYA, which is disappointing considering I could have just waited on adding the stabilizer. I just want to make sure that my next step should be draining a small amount of water in order to lower the CYA, before I address all other chemical levels.
    Am I right that this should be my first step? Is it just guesswork when it comes to how much water to drain/add? Is there anything crucial weíre missing? We really appreciate this website and the tremendous help itís been to us!
    Round 24' above ground; 13K gallons (approx.); Hayward SwimPro Cartridge Filter System; 1.5 hp Hayward Power-Flo LX Pump, single speed; Taylor K-2006 FAS-DPD Test Kit
    Jul 2015
    Central Valley CA
    1,107
    Re: First time owning a pool..Are we on the right track?
    Welcome to the forum!
    You can drain some to lower the CYA if you like but it's not necessary. Many that have pools with high sun exposure would target a CYA as high as yours. I would get the FC up to 7 or 8 then deal with raising the PH and TA. After you get those in range do an OCLT to make sure you did not get any algae while your FC was low if you pass OCLT you can just live with the high CYA for the rest of the season.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    30,414
    Your CYA is a bit high but I suggest you leave it and focus on getting the chlorine in there.....about 4-7 ppm and then KEEP it in there.
    a. Read the ABC's of Pool Water Chemistry. make sure you know how to adjust each parameter and understand why they may or may not need adjusting
    1. After that, add some 20 mule team borax until your pH gets to around 7.2
    2. Then adjust TA to around 70-80 ppm.
    3. Now, post your results again....let's see where you are.
    Jun 2016
    Jeffersonville, IN
    2
    Thank you guys so much for the advice!! I'm heading out this morning to get stocked up on borax and baking soda. The rest of the day will be spent (slowly) adding them to the pool water before waiting an hour or so to retest my levels.
    I'll post an update on my test results tonight, and in the meantime, I figured out how to post a picture of the pool before and after the SLAM. I can't think TFP enough for giving us the easy to follow instructions to get our pool back in beautiful condition.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Great job and nice pool!
    Thanks for supporting TFP!
