Thread: Filter question
    Filter question
    Hey guys. I have a bit of an odd situation going on... My pool is perfectly balanced and the water is absolutely sparkling clear. I was out vacuuming this evening and when finished, I let it sit for about a half hour while I did a few other chores. When I returned , to put the solar cover on and add chlorine, I noticed that there was some grayish colored sediment in some of the little dimples and things on the bottom. there
    was no wind this evening so it isn't possible that a bunch of stuff blew in. It can't be from the solar cover as it isn't on. I can only think of a 2 possibilities how this is happening. 1) there is a bunch of dirt under the steps that I can't get with the vacuum although it looks fairly clean. 2) dirt is going through the sand in my filter. Didn't have time to pull the ladder but I will this weekend to eliminate that possibility. I am 95% certain that the sand is not channeled as I just replaced and have been running the pump on low speed most of the time. Anything else I am missing? Any tips how I can get the dirt out? Thanks for your help.
    14000 gal AG vinyl liner. 150lb Hayward sand filter 1hp 2 speed pump.
    Jun 2012
    Butler, PA
    336
    Re: Filter question
    I always vacuum, leave the wand and suction head attached and operational, putter around with something else and then catch what settled that I disturbed about a half hour later. Usually takes me two sessions to clean it all. Lot of trees around me, 2 heavily farmed fields and lots of grass being mowed so I deal with a lot of drift that deposits more organics than I care for.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
