Results 1 to 17 of 17
Thread: Backwash section of filter leaking heavily
    May 2015
    Toronto
    183
    Hi,
    My backwash part of the filter is leaking about 15L a day. Could someone help guide on what I could do to
    fix it? Or best to higher a specialist?
    23K gal (I think), IG vinyl lagoona, Sta-Rite Hi-Rate Sand Filter T-240BP-1, Pentair Superflo VS 1.5 Pump (342001), June 2007, Taylor K-2006, Hayward Chlorine Feeder CL220, Water source from garden hose w/ water restrictions | 1HP Sta-Rite DYNA-GLAS MPRA6E-147L single speed pump
    38,303
    Re: Backwash section of filter leaking heavily
    Is it a push/pull or multi-port backwash valve?
    Sounds like you need to inspect/replace the seals inside.
    May 2015
    Toronto
    183
    I think multi port how do I tell? Filter model in description T-240BP-1
    38,303
    One you push/pull to change to backwash and one you rotate.
    Pull the 8 or so screws and inspect the spider gasket for damage.
    May 2015
    Toronto
    183
    The rotate one
    May 2015
    Toronto
    183
    Could I disassemble the filter without draining the pool? If so, what would be the proper steps to take?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    You don't have to drain anything, just turn off the pump and make sure a timer will not turn it back on until you have it put back together. If you can post a picture of the multiport valve (that's the name for the rotate one) we can tell you how to take it apart.
    Love TFP? Become a
    TFP Supporter!
    May 2015
    Toronto
    183
    Thanks, my filter model is in the signature, all original parts. Does that help?
    T-240BP-1
    also, maybe a new filter would outweigh cost of repairs?
    Jul 2009
    Houston, Texas
    9,396
    If the top of your multiport valve looks like this, you remove the screws and pull the top up out of the multiport valve. Turn it over and check the condition of the spider gasket. It is the rubber gasket on the diverter that looks a little like a wheel with spokes. If it is loose or torn it will need to be replaced. The parts to repair the multiport should be less than $100. Replacing the whole filter would cost hundreds.
    Love TFP? Become a
    TFP Supporter!
    May 2015
    Toronto
    183
    It seems parts for my filter are discontinued. Do I call the manufacturer?
    May 2015
    Toronto
    183
    I spoke to the company that built my pool, they advised the parts would be around 190 and labor 140. I looked into Hayward filter as many of you had, and they advised that it would not be compatible with my plumbing. Could someone advise if this information is correct or they are just providing incorrect information?
    i tend to trust TFP more than any other pool nowadays
    May 2015
    Toronto
    183
    Could anyone chime in on this?
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Parts quotes are hard to second guess.
    The OE parts may be discontinued, but since this is the company that installed the equipment in the first place you've got to give them the benefit of the doubt. They know exactly what they put in, so I'd expect they either have parts that they know are compatible or still have some of the OE gaskets kicking around on their own shelf.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    May 2015
    Toronto
    183
    Quote Originally Posted by RyanMcC View Post
    I guess my question was replacing the filter with another one all together. They mentioned that Hayward filter would not work with my current set-up. I thought all sand filters are made pretty much universal?
    38,303
    Sounded like the leak was just the gasket. That may be the same for other valves.
    Try contacting inyopools.com ... they are pretty good about finding hard to find parts.
    You can use any filter you want ... they are all plumbed with PVC. You can not mix and match backwash valves and filters.
    I have yet to see a picture of what you are dealing with.
    Looks like here is a manual show the disassembly: https://images.inyopools.com/cloud/d...istalfloom.pdf
    May 2015
    Toronto
    183
    When I called the individuals that built my pool, the representative advised that if I stick to the same brand of filter I do not need to change my plumbing, but if I change brands, I would require new plumbing. I am confused.
    I will take a photo after work today.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    It's probably a matter of the hard plumbing not being in exactly the right position for another model filter to fit right in. Hacking pool plumbing is not fun at all.
