Thread: Recommended order of action
    Jun 2016
    Bellevue, NE
    6
    Since my pool was opened, the CYA levels have dropped (unless the pool openers didn't add enough), thus my chlorine levels won't stay up.
    Current levels as tested with TF-100 kit: (89 degrees)
    FC - 2.5
    TC - 3.0
    CYA - 20
    PH - 7.4
    I dumped a gallon of Bleach 8.25% and a bag of shock in the pool this morning after seeing the pool was cloudy. Yesterday the chlorine was lower so I'm sure it will be lower again tomorrow. I'm pretty sure I need to do the SLAM thing. My question is does it matter if the CYA level is that low before I start dumping bleach in it go get it to shock levels? I'm going to wait till this evening to start. I have stabilizer on order to bring the CYA up but it won't be here for a few days. Do you recommend SLAMing it now or waiting and bring CYA up first?
    Also, with the CYA that low, what should I bring the FC up to? The CYA/FC chart looks like it only starts at 60 for SWG pools.
    Thanks for the help!
    Scott
    IG 23,700 Gallon Vinyl lined Pool
    Sand Filter
    SWG
    Bellevue, NE
    Jun 2014
    15,268
    Re: Recommended order of action
    Hello Scott and welcome to TFP! With your CYA at 20, just keep your SLAM FC level at 10. Treat it like a non-SWG pool for now. Don't go any higher on CYA than 30 until you pass your SLAM. Later when you increase CYA, then increase the FC accordingly on the Chlorine/CYA Chart (link below). Good luck!
    Jun 2016
    Bellevue, NE
    6
    Quote Originally Posted by Texas Splash View Post
    So if I pass the SLAM will I need to still need to increase the FC to say 24 when I get CYA to 60? Or would it be safe to just start keeping it at normal levels of 3-6?
    Thanks again for the help. I think I just cleared out Walmart of all their bleach!
    Sand Filter
    SWG
    Bellevue, NE
    Jun 2014
    15,268
    Once you pass the SLAM, then you'll increase your CYA to a minimum of 70 for your SWG pool and maintain your FC in that 4-6 range.
    Jun 2016
    Bellevue, NE
    6
    Awesome! Thanks! Guess I didn't need to buy so much bleach after all.
    Sand Filter
    SWG
    Bellevue, NE
