Thread: Pool build in Cancun, Mexico PART#3
    cancuntom's Avatar
    Mar 2009
    Cancun, Mexico
    This is a kind of a regress in my story back to Part 1. I thought more detail was interesting enough due to the peculiar problems with digging a large hole in the Cancun area. Once you dig about 18" of top soil out you hit solid rock. The backhoe that the PB used had a attachment on it that was a huge jackhammer. Many people build there pools here partially out of the ground. Maybe one or two feet. The reason is: they don't have to dig through all that rock to get the depth they want. We didn't go that route. The jackhammer was hammerin' away for 5 days straight from 8am to 5pm. It only stopped when he changed to a scoop to empty the rock pieces into a waiting dump truck. To do this he had to back into our driveway with his scoop full then turn 90ยบ then duck in under the power lines, raise it back up and proceed across the street and discharge it into the side of the dump truck. Then he would reverse the entire process to go back into the yard to get another scoopful. Here are a few pictures:
    The backhoe arrives:
    He scrapes the remaining sod off the pool location:
    We start to dig the hole:
    Lifting out the rocks:
    Working the rocks with the jackhammer attachment:
    The finished hole:
    My neighbors endured the noise and vibrations for 5 continuous days. God bless them....not one complaint. Before we started the hole, I delivered each one of them a letter warning about and explaining what we were about to do.
    Pool size: 14,300 gals. in-ground
    Filter: Aster99 Sand
    Flow: 22m3/h
    Construction: concrete block/Stucco/Glass mosaic tile
    Pump: 2hp, 3450rpm, 220V
    Heater: RayPak P-R206AE
    Check out our Mexican Adventures on my Caribbean Webpage & leave a comment!
    Rocklin, Ca
    Re: Pool build in Cancun, Mexico PART#3
    An invite to swim and a cold one may help their ears feel better
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
