Thread: Pump Recommendations
    Just had a Hayward Super Pump model C48K2N143B1 (the bottom left reads SP-1607-Z1-M) finally go on me. We have a kidney shaped in-ground pool with about 19,000-21,000 gallons capacity. Our season here is short so I only run the pool for about two months. I'll be looking to pair it with a Pro-Grid DE 4820. I don't know much about pumps as we inherited the pool a few years ago. My basket set up is in great shape, so I guess I'm just looking to replace the pump motor? I'm looking for a new one ASAP and am looking for suggestions. Thank you.
    Chad
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,247
    Re: Pump Recommendations
    Here's a recent thread that might be of interest
    Installed a variable speed motor on my pump - wow, what a difference.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    The wet side usually doesn't go bad, you could replace the motor and move on. Seems to be a good deal listed below.
    Your motor is the c48k 1hp round flange motor. Easy to find/replace. The SP1607 is the pump model. Also replace shaft seal.
    is your setup 115V or 230V?
    parts diagram: Hayward Super Pump Parts - INYOPools.com
    I think any of these would work:
    Single speed: A.O. Smith 1 HP Round Flange Up Rate Motor - UST1102 - INYOPools.com
    Dual Speed: A.O. Smith 1 HP Full Rate Two Speed Motor W/ Timer - Round Flange (B975T,B2975T) - INYOPools.com
    Dual Speed: A.O. Smith 1 H.P Round Flange Dual Speed Full Rate Motor W/Out Switch (STS1102, STS1102RV1) - INYOPools.com
    Variable Speed: A.O. Smith 1.65 HP Variable Speed Pool Pump Motor Round Flange - ECM16CU - INYOPools.com
    (Same price as 2-speed with timer. Seems to be a good deal on sale!)
    Shaft seal: Hayward SHAFT SEAL 201 (GENERIC) - AS-1521 - INYOPools.com
    Bobo, thank you for the links and information. I appreciate the time you put into it. Got everything up and running. Thank you again.
    Apr 2011
    Murrieta, CA
    2,360
    What did you go with?
