Thread: PH is staying the same
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Is it normal for PH to stay the same for long periods of time? Mine is at 7.5, and I haven't had to add any MA for over two weeks. Getting large bather loads on weekends, and TA is hanging right at 70. FC is good at 6, and CC is 0. Water temp is 86-87 range. Thanks!!!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: PH is staying the same
    congratulations, it sounds like you have found the "sweet spot" for TA in your pool!
    When the TA is at a level it likes, your ph should be fairly steady barring any unforeseen additions.
    Each pool is different. My current pool is fairly steady but once every few months goes to 7.3 which
    I believe is caused by the neighbors annoying red pine dumping tons of needles in.
    My last house/pool had steady 7.5 year round.
    Dolphin E10 Cleaning Robot.
    30,408
    My pool would start at around 7.4 in the Spring and I would need to add acid once or at most, twice over the season. I went one summer with no acid added at all.
    8.0 was my trigger. I let it float there for a long time. I was lucky as to how easy that pool was to maintain.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Two weeks? Man I haven't added any in almost 2 years. Several others here like me too.
    I guess I'm lucky.
    Quote Originally Posted by kywildcats View Post
    Divin Dave,
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Quote Originally Posted by Divin Dave View Post
    I guess I'm lucky.
    This is my first full year with a pool. I'm shooting for your record, Dave!!
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Gimme some cash and I'll go dump some borax in his pool!
