Results 1 to 7 of 7
Thread: Intermatic Timer ON OFF Manual switch not working
    Mar 2016
    Austin
    11
    I left my Intermatic Timer open during a rainstorm and now the manual timer on off switch does not work. The GFCI tripped at the breaker so I assume there was a short with the water. Now, The pump is always on and I have to switch the breaker to turn pump off.
    I removed the timer dial and sprayed contact cleaner and moved switch back and forth. No luck after doing that. Is the switch repairable or does it need to be replaced?
    Thanks
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Intermatic Timer ON OFF Manual switch not working
    Is the timer dial rotating at all?
    Isolated Spa - 345 Gallons
    Mar 2016
    Austin
    11
    Timer is working and the gears are moving.
    Is the switch that would need to be cleaned behind the metal box where the gears are?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    The contacts are probably welded
    Factory Warranty Station for:
    Mar 2016
    Austin
    11
    Quote Originally Posted by Pool Clown View Post
    Does that mean it is a goner?
    Thanks
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Pull the circuit board out of the plastic housing, there should be tabs on both sides holding it in. Watch the contacts as you switch it on and off. That'll tell you if the contacts are welded.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    If the motor isn't shutting off when mechanically turned off, the contacts are stuck together, and you won't see any contacts opening when you switch it on and off. If you can open the contacts (pry them apart) without bending the contact arms, and then reface the contacts, you might be able to bring it back. Refacing the contacts would be necessary to keep the same thing from happening again but no guarantee. One the contacts get roughed up either by welding or sanding, they are likely to stick again, especially if a lot of amperage is drawn across them.
